Saltar al contenido principal
Inglés
Español
Paso 17
Cut the lead off of the power supply included in the kit. You can cut the power supply leads as short as you desire to reduce clutter. Strip the outer sheath off the wires. You can use either wire strippers with the correct size hole, or you can use a pair of wire cutters to carefully cut just the outer sheath.
  • Cut the lead off of the power supply included in the kit.
  • You can cut the power supply leads as short as you desire to reduce clutter.
  • Strip the outer sheath off the wires. You can use either wire strippers with the correct size hole, or you can use a pair of wire cutters to carefully cut just the outer sheath.
Insertar traducción aquí
