Inglés
Español
Paso 12
Solder the pins to the board on the printed side of the PCB. Unsure of how to properly through-hole solder? Check out our technique guide. You can even use a thin piece of wire and practice with a hole on an unused trace.
  • Solder the pins to the board on the printed side of the PCB.
  • Unsure of how to properly through-hole solder? Check out our technique guide. You can even use a thin piece of wire and practice with a hole on an unused trace.
  • Try to solder quickly and efficiently. Prolonged application of heat to any of the component pins can transfer enough heat to damage it.
Insertar traducción aquí
