Inglés
Español
Paso 11
Place the pins of the voltage regulator through the holes indicated in step 7. Adjust the pins if necessary. There should be just a small portion of the pin sticking up through the top side of the PCB. If the pins do not stick through the board, adjust the pin bends so that they do.
  • Place the pins of the voltage regulator through the holes indicated in step 7. Adjust the pins if necessary.
  • There should be just a small portion of the pin sticking up through the top side of the PCB. If the pins do not stick through the board, adjust the pin bends so that they do.
Insertar traducción aquí
