Saltar al contenido principal
Inglés
Español
Paso 10
Use needle nose pliers to bend just the tips (approximately 2 mm) of the pins 90° up so that they are pointing the same direction as the IC face. If you bend too much of the pins, they will not be able to reach their assigned holes.
  • Use needle nose pliers to bend just the tips (approximately 2 mm) of the pins 90° up so that they are pointing the same direction as the IC face.
  • If you bend too much of the pins, they will not be able to reach their assigned holes.
Insertar traducción aquí
