Saltar al contenido principal
Inglés
Español
Paso 9
The voltage regulator has 3 pins: Pin 1: V in (5 V) Pin 2: V out (3.3 V)
  • The voltage regulator has 3 pins:
  • Pin 1: V in (5 V)
  • Pin 2: V out (3.3 V)
  • Pin 3: "Adjust"
  • Use a pair of pliers to carefully bend pin 1 down 90°, pin 3 up 90° and pin 2 up as far as possible without touching pin 3.
  • Do not worry about getting exact angles, as you will likely need to adjust the pins when you go to fit the IC to the PCB.
  • Do not repeatedly bend and unbend the pins, as repeated bending will weaken the metal and eventually cause it to break.
Insertar traducción aquí
