Saltar al contenido principal
Inglés
Español
Paso 5
The power supply is attached to the upper case half with one 5.38 mm Phillips screw. Use a #1 Phillips screwdriver to remove the screw and then remove the power supply. Do not lose this screw. You will be using it to secure the new power supply to the upper case half.
  • The power supply is attached to the upper case half with one 5.38 mm Phillips screw.
  • Use a #1 Phillips screwdriver to remove the screw and then remove the power supply.
  • Do not lose this screw. You will be using it to secure the new power supply to the upper case half.
Insertar traducción aquí
