Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward.   The battery should slide out. Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward.   The battery should slide out.
  • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
Insertar traducción aquí
