Saltar al contenido principal
Inglés
Holandés
Traduciendo paso 3
Paso 3
Pull the plastic hard drive connector straight away from the hard drive.
  • Pull the plastic hard drive connector straight away from the hard drive.
  • This is a bit tricky. Try rocking the connector gently while pulling with even pressure. If you bend the pins, do your best to straighten them, using the hard drive connector as a guide.
  • Hard drive remains.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Insertar traducción aquí
