Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 12
Locate the oil dipstick. It has a yellow handle, is near the back center of the engine bay, and is embossed with "Engine Oil". Pull out the oil dipstick, wipe it off, place it all the way back into its hole, and remove it again. Check the oil level on the end of the dipstick. It should be within the "safe" marks or slightly above.
  • Locate the oil dipstick. It has a yellow handle, is near the back center of the engine bay, and is embossed with "Engine Oil".
  • Pull out the oil dipstick, wipe it off, place it all the way back into its hole, and remove it again.
  • Check the oil level on the end of the dipstick. It should be within the "safe" marks or slightly above.
  • This is not your actual oil level, but a pre-check to make sure the engine will not run dry when you first start it. The oil level will drop slightly after the first run when oil fills the new oil filter.
  • Add oil if the oil level is below the "safe" area of the dipstick. Place the oil dipstick all the way back in its hole.
Insertar traducción aquí
