Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 7
Wet the tip of a clean gloved finger with fresh oil and spread the oil around the new oil filter's seal. Place the threaded end of the oil filter onto the engine's oil filter threads, being careful to not get dirt or debris on the filter's gasket. Turn the filter clockwise by hand until it is snug.
  • Wet the tip of a clean gloved finger with fresh oil and spread the oil around the new oil filter's seal.
  • Place the threaded end of the oil filter onto the engine's oil filter threads, being careful to not get dirt or debris on the filter's gasket.
  • Turn the filter clockwise by hand until it is snug.
  • If the filter is difficult to turn at the beginning of its threads, stop! You may be cross threading the oil filter. Re-align the oil filter and try again.
  • Do not over-tighten your oil filter by using a wrench. Doing so may cause the oil filter seal to leak and will make removing the oil filter very difficult in the future.
  • Remove the oil drain pan from underneath the truck.
Insertar traducción aquí
