Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 20 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 6
Paso 6
Using the sharp end of a spudger, disconnect the connector for the blue and white power cables.  Again, be careful to pry up only on the connector. It is very easy to break the connector from the board, so be careful.
  • Using the sharp end of a spudger, disconnect the connector for the blue and white power cables. Again, be careful to pry up only on the connector.
  • It is very easy to break the connector from the board, so be careful.
  • The key is to apply force in two directions, down to keep the surface board connections intact, up to release the connector.
  • The upper case is now free and can be removed from the computer.
Insertar traducción aquí
