Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a plastic opening tool to gently pry the bottom cover loose. Do not use excessive force at risk of damaging the antenna, which is under this casing. Pull the cover from the front of the phone after the back is loose.
  • Use a plastic opening tool to gently pry the bottom cover loose.
  • Do not use excessive force at risk of damaging the antenna, which is under this casing.
  • Pull the cover from the front of the phone after the back is loose.
Insertar traducción aquí
