Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel. Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
  • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
  • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
  • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
Insertar traducción aquí
