Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Paso 2
Use the nylon spudger to pry the back casing near the hinges for the screen. Continue to pry along the edge of the back case until the back is ready to be removed. Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  • Use the nylon spudger to pry the back casing near the hinges for the screen.
  • Continue to pry along the edge of the back case until the back is ready to be removed.
  • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
Insertar traducción aquí
