Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads. Use the Phillips #0 to remove four 9mm screws.
  • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
  • Use the Phillips #0 to remove four 9mm screws.
  • Use the Phillips #0 to remove seven 6mm screws.
Insertar traducción aquí
