Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 3
Starting at a bottom corner, use the spudger to separate the rear case from the front display. Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step. Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
  • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
  • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
Insertar traducción aquí
