Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 4
Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously. Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
  • Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
  • Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
  • Be careful not to pull too hard on the cable connecting the power button control circuit board and the secondary control circuit board to the main circuit board
Remueve la placa de circuito del botón de encendido de su soporte agarrándolo del lado izquierdo, y tirando hacia adelante y a la izquierda simultáneamente.
Presiona la pestaña que contiene la segunda placa de circuitos con el spudger y tira hacia adelante para removerla.
Ten cuidado de no tirar demasiado fuerte del cable que conecta ambas placas a la principal.
