Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 3
Disconnect the eight indicated connectors by placing a spudger beneath the wired side of each one and lifting up.
  • Disconnect the eight indicated connectors by placing a spudger beneath the wired side of each one and lifting up.
  • Use care when disconnecting some of the smaller connectors. A forceful prod with the spudger may accidentally break them off the logic board.
Desconecta los ocho conectores indicados colocando un spudger debajo de cada uno y levantándolos.
Ten cuidado al desconectar algunos de los conectores más pequeños. Un golpe fuerte con el spudger puede romperlos accidentalmente de la placa lógica.
[* black] Disconnect the eight indicated connectors by placing a spudger beneath the wired side of each one and lifting up.
[* icon_caution] Use care when disconnecting some of the smaller connectors. A forceful prod with the spudger may accidentally break them off the logic board.
