Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 8
Look for the antenna which is located at the bottom end of the device.  Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna. Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna. With your hands finish prying apart the antenna  by lifting it up.
  • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
  • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
  • With your hands finish prying apart the antenna by lifting it up.
Insertar traducción aquí
