Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 16
Use an opening pick to slice through the adhesive directly underneath the battery connector terminal. There's a small standoff in the case that helps seat this connector. The pick may be obstructed by this. Simply work the pick around each side of the standoff to slice through the adhesive.
  • Use an opening pick to slice through the adhesive directly underneath the battery connector terminal.
  • There's a small standoff in the case that helps seat this connector. The pick may be obstructed by this. Simply work the pick around each side of the standoff to slice through the adhesive.
Insertar traducción aquí
