Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 20 guías que incluyan este paso.
Inglés
Español
Paso 6
Insert the flat edge of a spudger into the bottom right corner of the device. Twist the spudger to widen the gap between the display assembly and the rear case. Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
  • Insert the flat edge of a spudger into the bottom right corner of the device.
  • Twist the spudger to widen the gap between the display assembly and the rear case.
  • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
  • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
Inserta el borde plano de un spudger en la esquina inferior derecha del dispositivo.
Gira el spudger para ampliar el espacio entre el ensamblaje de la pantalla y la caja trasera.
Desliza el extremo plano del spudger por el lado derecho del teléfono para romper el adhesivo que sostiene la pantalla en su lugar.
[* black] Insert the flat edge of a spudger into the bottom right corner of the device.
[* black] Twist the spudger to widen the gap between the display assembly and the rear case.
[* black] Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
[* icon_caution] Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
