Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws, Remove the two screws with a Phillips #00 screwdriver.
  • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
  • Remove the two screws with a Phillips #00 screwdriver.
  • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
  • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
Insertar traducción aquí
