Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 33 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the fan out of the mini for enough clearance to access its connector. Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board. Do not pry at the socket, or you may rip it from the logic board.
  • Lift the fan out of the mini for enough clearance to access its connector.
  • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
  • Do not pry at the socket, or you may rip it from the logic board.
  • Remove the fan.
Levanta el ventilador de la mini para tener suficiente espacio para acceder a su conector.
Toma todos los cables y gentilmente tira para desconectar el fan de la placa lógica. Alternativamente, desliza un spudger debajo de los cables y empuja hacia arriba para destrabar el conector.
No hagas palanca en el zócalo, o lo arrancarás de la placa logica.
Remueve el ventilador.
[* black] Lift the fan out of the mini for enough clearance to access its connector.
[* black] Grab all the wires at once and gently pull '''straight up''' to disconnect the fan from the logic board. Alternatively, slide a spudger underneath the wires and pry up to disengage the connector.
[* icon_caution] Do '''not''' pry at the socket, or you willmay rip it from the logic board.
[* black] Remove the fan.
