Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 13
Paso 13
Peel up the Bluetooth data cable from the adhesive on the upper case, removing tape as necessary. Disconnect the Bluetooth data cable from the upper case.
  • Peel up the Bluetooth data cable from the adhesive on the upper case, removing tape as necessary.
  • Disconnect the Bluetooth data cable from the upper case.
  • Lift the Bluetooth board and attached cable off the upper case.
  • To install your replacement upper case, install your current Bluetooth board, antenna, and keyboard into the replacement case and reassemble your computer.
Insertar traducción aquí
