Saltar al contenido principal
Inglés
Español
Paso 8
Remove the two silver Phillips screws holding the SuperDrive to the internal frame. Rotate the internal frame 180 degrees and remove two more silver Phillips screws. Rotate the internal frame so that the interconnect board connector is facing you.
  • Remove the two silver Phillips screws holding the SuperDrive to the internal frame.
  • Rotate the internal frame 180 degrees and remove two more silver Phillips screws.
  • Rotate the internal frame so that the interconnect board connector is facing you.
  • Remove the two silver Phillips screws holding the SuperDrive to the interconnect board connector.
Insertar traducción aquí
