Saltar al contenido principal
Inglés
Español
Traduciendo paso 6
Paso 6
When inserting the headlight assembly back into the housing, make sure that the housing locator guides fit into the catches on both sides of the assembly. Push the assembly into the housing until you hear it click into place. Again use the 5mm nut driver to turn the locking nut that locks the assembly in its housing.
  • When inserting the headlight assembly back into the housing, make sure that the housing locator guides fit into the catches on both sides of the assembly.
  • Push the assembly into the housing until you hear it click into place.
  • Again use the 5mm nut driver to turn the locking nut that locks the assembly in its housing.
  • Turn on the ignition and check that the new bulb works. Close the hood.
Insertar traducción aquí
