Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Be sure to shut power to the tablet off and remove any external power source before beginning this step. Insert one of the blue plastic opening tools between the glass display and the edge of the tablet's outer shell to break the seal around the display. It doesn't matter where you start the process, but once you form a gap, continue opening the gap around the edge of the device. The display assembly and back casing should gently come apart after a gap is formed around the perimeter.
  • Be sure to shut power to the tablet off and remove any external power source before beginning this step.
  • Insert one of the blue plastic opening tools between the glass display and the edge of the tablet's outer shell to break the seal around the display. It doesn't matter where you start the process, but once you form a gap, continue opening the gap around the edge of the device.
  • The display assembly and back casing should gently come apart after a gap is formed around the perimeter.
  • This step requires quite a bit of force to open the tablet. Don't be shy about it. Once you do make a gap, be careful not to pinch your fingers!
Insertar traducción aquí
