Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 4
Once the draining oil has slowed to a drip, wipe off the area around the oil drain and reinsert the oil drain plug. Twist the oil drain plug into place using your hand, then finish tightening it clockwise with the box end wrench. Ensure that the drain plug is tight, but do not over-tighten it. You may risk stripping the threads or cracking the oil pan—a costly error.
  • Once the draining oil has slowed to a drip, wipe off the area around the oil drain and reinsert the oil drain plug.
  • Twist the oil drain plug into place using your hand, then finish tightening it clockwise with the box end wrench.
  • Ensure that the drain plug is tight, but do not over-tighten it. You may risk stripping the threads or cracking the oil pan—a costly error.
Insertar traducción aquí
