Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off. Insert a SIM card eject tool or a  paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
  • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
  • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
  • Push the tool into the hole until you see the card pop out.
Inserta la herramienta de expulsión de tarjeta SIM o un clip en el agujero al lado a la ranura de la tarjeta SIM, la cual está localizada justo debajo del botón de encendido.
Presiona la herramienta dentro del agujero hasta que vea salir la bandeja.
[* icon_note] Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
black] Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
[* black] Push the tool into the hole until you see the card pop out.
