Saltar al contenido principal
Inglés
Español
Paso 3
This will be the step where you teardown the controller not take it apart. To remove the 4 buttons (2 on each side), first lift out the R1 (or L1) button.  This may require you to wiggle the button.
Removing the L1,L2 and R1,R2 buttons.
  • This will be the step where you teardown the controller not take it apart.
  • To remove the 4 buttons (2 on each side), first lift out the R1 (or L1) button. This may require you to wiggle the button.
  • From here, you will have to apply force to tear out the R2 (or L2) button and the plastic it is connected to. In the 2 pictures (ots) you can see one side taken apart and the other as it normally is.
Insertar traducción aquí
