Saltar al contenido principal
Inglés
Holandés
Paso 5
Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
Closing
  • Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
  • If the case doesn't seem to close properly as it did before, do not keep on trying to tighten the screw down; you will strip the screw.
  • If the case doesn't close properly, you will need to open the device back up and remove a tiny bit of the paper until it does close, that way it will retain its water resistance.
Insertar traducción aquí
