Saltar al contenido principal
Inglés
Español
Paso 5
Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
Closing
  • Once you have confirmed that the paper will apply the necessary pressure, you can then put the screws back in.
  • If the case doesn't seem to close properly as it did before, do not keep on trying to tighten the screw down; you will strip the screw.
  • If the case doesn't close properly, you will need to open the device back up and remove a tiny bit of the paper until it does close, that way it will retain its water resistance.
Una vez que has comprobado que el papel aplica la presión necesaria, puedes volver a colocar los tornillos.
En caso de que no cierre correctamente, no sigas apretando, o puedes romper los tornillos.
En caso de que no cierre correctamente, vuelve a abrir el dispositivo, quita un poco de papel hasta que cierre correctamente. Así podrá mantener su resistencia al agua.
