Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 5
Once the draining oil has slowed to a drip, clean the area around the drain plug hole with a clean towel or rag and replace the oil drain plug. Screw in the oil drain plug by hand, turning it clockwise as far as possible. Finish tightening the drain plug by using a 17 mm box end wrench or socket.
  • Once the draining oil has slowed to a drip, clean the area around the drain plug hole with a clean towel or rag and replace the oil drain plug.
  • Screw in the oil drain plug by hand, turning it clockwise as far as possible. Finish tightening the drain plug by using a 17 mm box end wrench or socket.
  • Only tighten the drain plug until it is snug. Over-tightening the oil drain plug can strip the threads or crack the oil pan.
Insertar traducción aquí
