Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 16 guías que incluyan este paso.
Inglés
Español
Paso 3
While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad. Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
  • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
Mientras sostiene el vaso con la ventosa, deslice la punta de una púa de apertura en el espacio entre el vidrio y el cuerpo del iPad.
No inserte el pico de apertura más profundo que el bisel negro en el costado de la pantalla. Insertar demasiado el pick puede dañar el LCD.
[* black] While holding the glass up with the suction cup, slideinsert the point of an opening pick into the gap between the glass and body of the iPad.
[* icon_caution] Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
