Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Examine your replacement part, and your original display carefully to be sure they match. Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component. Desolder the six solder pads from the lower left of the display to remove the sensor assembly cable.
  • Examine your replacement part, and your original display carefully to be sure they match.
  • Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component.
  • Desolder the six solder pads from the lower left of the display to remove the sensor assembly cable.
Insertar traducción aquí
