Saltar al contenido principal
Inglés
Español
Paso 15
Holding your hand down over the sensitive internals around the trigger area (to prevent them from dislodging), slide the cocking mechanism all the way forward. With the cocking mechanism forward, you should be able to reinstall the trigger (if you removed it earlier). With the cocking mechanism forward, you should be able to reinstall the trigger (if you removed it earlier).
Reinstall trigger.
  • Holding your hand down over the sensitive internals around the trigger area (to prevent them from dislodging), slide the cocking mechanism all the way forward.
  • With the cocking mechanism forward, you should be able to reinstall the trigger (if you removed it earlier).
Insertar traducción aquí
