Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 40 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Remove the following five Phillips  screws holding the lower support bracket in place: Four 3.2 mm screws
  • Remove the following five Phillips screws holding the lower support bracket in place:
  • Four 3.2 mm screws
  • One 1.7 mm screw
  • On at least some EMC 2544 machines, all five screws are the same size.
  • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Insertar traducción aquí
