Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Locate the oil filter and 17 mm hex oil drain plug. The oil filter is facing forward off the front of the engine, along its center line. The oil drain plug is on the bottom of the engine, below the oil filter. Place the oil drain pan under the oil drain plug and oil filter.
  • Locate the oil filter and 17 mm hex oil drain plug. The oil filter is facing forward off the front of the engine, along its center line. The oil drain plug is on the bottom of the engine, below the oil filter.
  • Place the oil drain pan under the oil drain plug and oil filter.
  • Be sure to position the drain pan so that it will catch the oil when it is streaming out of the pan.
Insertar traducción aquí
