Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 4
Wipe the area on the oil pan around the drain plug hole with a clean rag or towel. Reinstall the drain plug and tighten it with a box end wrench until it is snug. Do no over-tighten the drain plug. Doing so may strip the threads or crack the oil pan. You can always go back later and tighten it more, if need be.
  • Wipe the area on the oil pan around the drain plug hole with a clean rag or towel.
  • Reinstall the drain plug and tighten it with a box end wrench until it is snug.
  • Do no over-tighten the drain plug. Doing so may strip the threads or crack the oil pan. You can always go back later and tighten it more, if need be.
Insertar traducción aquí
