Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board. Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
  • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
  • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
  • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
Insertar traducción aquí
