Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 25 guías que incluyen este paso.
Inglés
Español
Paso 2
Apply a suction cup halfway up the heated side. Be sure the cup is completely flat on the screen to get a tight seal. While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
  • Apply a suction cup halfway up the heated side.
  • Be sure the cup is completely flat on the screen to get a tight seal.
  • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
  • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
  • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
Coloque con cuidado una ventosa hasta la mitad del lado calentado.
Asegúrese de que la taza esté completamente plana en la pantalla para obtener un sello hermético.
Mientras sostiene el iPad hacia abajo con una mano, tire de la ventosa para separar ligeramente el conjunto del panel frontal de la carcasa trasera.
Tenga cuidado de solo levantar el vidrio lo suficiente como para insertar una apertura de pico, y corre el riesgo de romper el vidrio.
-[* black] Carefully place a suction cup halfway up the heated side.
+[* black] Apply a suction cup halfway up the heated side.
[* black] Be sure the cup is completely flat on the screen to get a tight seal.
-[* black] While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel assembly from from the rear case.
-[* icon_caution] Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
+[* black] While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
+ [* icon_note] Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
+ [* icon_caution] Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
