Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet. The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet.
Levante el disco duro del borde más cercano a la placa y extráigalo ligeramente de su alojamiento.
El disco duro todavía estará conectado por su cable SATA; No intente extraerlo completamente todavía.
