Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the 7.9 mm T6 Torx screw securing the power supply and hard drive tray to the outer case.
  • Remove the 7.9 mm T6 Torx screw securing the power supply and hard drive tray to the outer case.
  • During reassembly, ensure the cables that run alongside the hard drive are tucked under the power supply. This will ensure the hard drive is properly seated. In addition, the antenna screw holes will not line up if there are cables in the way.
Insertar traducción aquí
