Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The SATA data connector has a clip that must be pressed to allow removal. While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board. While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
  • The SATA data connector has a clip that must be pressed to allow removal.
  • While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
El conector de datos SATA tiene un clip que debe ser presionado para permitir su desconexión.
Mientras presionas el clip con tu pulgar, levanta y desconecta el conector de datos SATA de su zócalo en la placa lógica.
