Saltar al contenido principal
Inglés
Español
Paso 17
This won't be required every time you change your oil. This signal will appear at specified mileage intervals for routine maintenance. See your owner's manual for details. The light is indicated on the dash between the tachometer and speedometer While the car is off, hold down the trip meter reset button. Turn the ignition on, but do not start the engine. Continue to hold the button for approximately 10 seconds, until the indicator turns off.
Resetting the Maintenance Required Signal
  • This won't be required every time you change your oil. This signal will appear at specified mileage intervals for routine maintenance. See your owner's manual for details.
  • The light is indicated on the dash between the tachometer and speedometer
  • While the car is off, hold down the trip meter reset button. Turn the ignition on, but do not start the engine. Continue to hold the button for approximately 10 seconds, until the indicator turns off.
Esto no será necesario cada vez que cambie su aceite. Esta señal aparecerá a intervalos de kilometraje específicos para el mantenimiento de rutina. Consulte el manual del propietario para más detalles.
La luz se indica en el tablero entre el tacómetro y el velocímetro
Mientras el automóvil está apagado, mantenga presionado el botón de reinicio del medidor de viaje. Encienda el encendido, pero no encienda el motor. Continúe presionando el botón durante aproximadamente 10 segundos, hasta que el indicador se apague.
