Saltar al contenido principal
Inglés
Español
Paso 16
Return the hood prop rod to its home in the clasp at the front of the engine. Gently lower the hood, and push down on it to make sure it latches. Be sure that you don't leave any trash on top of the engine, and make sure the oil filler cap and dipstick have returned to their respective places before closing the hood.
  • Return the hood prop rod to its home in the clasp at the front of the engine.
  • Gently lower the hood, and push down on it to make sure it latches.
  • Be sure that you don't leave any trash on top of the engine, and make sure the oil filler cap and dipstick have returned to their respective places before closing the hood.
  • Before driving anywhere, start the car and let it run for a couple minutes. While the engine is running, check underneath the car for any oil leaks. If oil is dripping from the drain plug you should first check for any cracks in the drain pan. If there are no cracks, you can turn off the car, and tighten the drain plug. Also, check again that the oil level has not gone outside the limits while the car was on.
Regrese la varilla del capo a su sitio en el cierre en la parte delantera del motor.
Baje suavemente el capo y presiónela para asegurarse de que se enganche.
Asegúrese de no dejar basura en la parte superior del motor, y asegúrese de que la tapa de llenado de aceite y la varilla medidora hayan regresado a sus lugares respectivos antes de cerrar el capo.
Antes de conducir a cualquier lugar, encienda el automóvil y déjelo funcionar durante un par de minutos. Mientras el motor está en marcha, revise si hay fugas debajo del automóvil
Si gotea aceite del tapón de drenaje, primero debe verificar si hay grietas en la bandeja de drenaje. Si no hay grietas, puede apagar el automóvil y apretar el tapón de drenaje.,verifique nuevamente el nivel de aceite
