Saltar al contenido principal
Inglés
Español
Paso 12
The hood should be "popped". Find the hood latch centered at the front of the hood, just above the Honda emblem. Push up on the latch and raise the hood. With one hand holding the hood up, use your other hand to raise the hood prop rod and insert it into the corresponding notch under the hood.  Voila!, your hood is propped up.
  • The hood should be "popped". Find the hood latch centered at the front of the hood, just above the Honda emblem.
  • Push up on the latch and raise the hood.
  • With one hand holding the hood up, use your other hand to raise the hood prop rod and insert it into the corresponding notch under the hood. Voila!, your hood is propped up.
Encuentra el pestillo centrado en la parte delantera , justo encima del emblema de Honda.
Empuje hacia arriba el pestillo y levante la capó
Con una mano sosteniendo el capó , utilice la otra mano para levantar la varilla de apoyo capó y la inserta en la ranura correspondiente bajo el capó. ¡Voila !, tu capó está apuntalado.
