Saltar al contenido principal
Inglés
Español
Paso 8
Pour the remaining oil out of the filter. Set it top-side down in the oil drain pan to allow any excess oil to drain. Now grab a clean rag or paper towel and reach up into the engine again to wipe off any oil from the face of the housing, where the new oil filter will seal against. You can exit from beneath the car, and remove the oil drain pan as well.
  • Pour the remaining oil out of the filter. Set it top-side down in the oil drain pan to allow any excess oil to drain.
  • Now grab a clean rag or paper towel and reach up into the engine again to wipe off any oil from the face of the housing, where the new oil filter will seal against.
  • You can exit from beneath the car, and remove the oil drain pan as well.
Vierta el aceite restante fuera del filtro. Colóquelo boca arriba en la bandeja de drenaje de aceite para permitir que se drene el exceso de aceite.
Ahora tome un paño limpio o una toalla de papel y vuelva a subir al motor para limpiar el aceite de la parte frontal de la carcasa, donde se sellará el nuevo filtro de aceite.
Puede salir por debajo del automóvil y también extraer la bandeja de drenaje de aceite.
