Saltar al contenido principal
Inglés
Español
Paso 7
From the underside of the car, locate the oil filter. It will be installed on the engine block just above the driver side axle shaft. Keep the oil drain pan nearby as you reach up to get a grip on the oil filter. Loosen it slowly and carefully, trying to avoid spilling oil. Remove the filter and keep it open side up to prevent spilling oil on yourself.
Changing the Oil Filter
  • From the underside of the car, locate the oil filter. It will be installed on the engine block just above the driver side axle shaft.
  • Keep the oil drain pan nearby as you reach up to get a grip on the oil filter. Loosen it slowly and carefully, trying to avoid spilling oil.
  • Remove the filter and keep it open side up to prevent spilling oil on yourself.
Desde la parte inferior del automóvil, ubique el filtro de aceite. Se instalará en el bloque del motor justo encima del eje del eje del lado del conductor.
Mantenga la bandeja de drenaje de aceite cerca mientras levanta la mano para agarrar el filtro de aceite. Aflojarlo lenta y cuidadosamente, tratando de evitar derramar aceite.
Retire el filtro y manténgalo abierto hacia arriba para evitar derramar aceite sobre usted mismo.
