Saltar al contenido principal
Inglés
Español
Paso 3
Locate the 17 mm hex drain plug. It will be on the driver side of the oil pan facing the rear of the car. There's a sign pointing to it if you can't find it. Slide the oil drain pan beneath the drain plug so that it catches the oil when you start to drain it.
  • Locate the 17 mm hex drain plug. It will be on the driver side of the oil pan facing the rear of the car.
  • There's a sign pointing to it if you can't find it.
  • Slide the oil drain pan beneath the drain plug so that it catches the oil when you start to drain it.
Ubique el tapón de drenaje hexagonal de 17 mm. Estará en el lado del conductor del cárter de aceite orientado hacia la parte trasera del automóvil.
Hay un letrero que lo señala si no puede encontrarlo.
Deslice la bandeja de drenaje de aceite debajo del tapón de drenaje para que atrape el aceite cuando comience a drenarlo.
